EGR Removal 1996 4jg2 Mu (3.1 auto)
MightyMO0o
Post by MightyMO0o »
Hey guys I’ve read through every thread on here to do with the Egr removal, but haven’t seen any that are the same set up as mine. It would appear I have 2 sets of solenoids (one on drivers side corner) and one where I’ve seen everybody else’s in the passenger side corner. As far as I understand if I remove all vacuum lines attaching to these 2 valves, I’m good to go? I’m not worried about the idle up for the ac. And everything I remove I just block right? Really appreciate any help, thanks guys
Kerry
P.s I just traced 2 vac lines coming from the drivers side corner set of solenoids to go to a valve looking thing on my exhaust just beside where the rear drive shaft connects to the gearbox. Does this have anything to do with it?
Re: EGR Removal 1996 4jg2 Mu (3.1 auto)
That one is cold start. Unless you disable the device in the exhaust leave this one alone
