Trans mount
shane0nz
Trans mount
Post by shane0nz »
Hey guys what is the big centre bolt for on isuzu trans mount? Im getting a knock when i turn engine off, the two slanted rubbers here look fine, is there supposed to be rubber around that centre bolt and should it be tight? Cheersimage.jpeg
Re: Trans mount
A guess would be that the bolt is a fail safe like the hook shapes on the engine mounts. If an engine mount rubber breaks the engine cant fall out and I suspect this bolt has a similar function. Leave it the way it is.
shane0nz
Re: Trans mount
Post by shane0nz »
Turns out the new engine mounts slightly raised the engine enough for exhaust mount to hit the floor
Re: Trans mount
I wondered about that. My old bighorn had this issue
shane0nz
Re: Trans mount
Post by shane0nz »
Yep another 6 months on the road for the mu, choice
