Front cover gasket?
jellis
Front cover gasket?
Post by jellis »
Anyone know where i can get the gasket that goes between block and aluminium timing case?
i have oil and water leaking into timing cover through bolt holes.
supposedly the gaskets are different between belt and gear driven....
I may just gasket glue the whole thing back together. any one done this?
Re: Front cover gasket?
This might help you but in the UK
http://www.smsdiesel.ie/en/industrial/i ... 8971172420
Its the jackeroo engine you have so ask your holden dealer
Mu never had a gear drive engine
jellis
Post by jellis »
i can only get the gasket for gear driven.
I have no option but to use some gasket sealant as motor has to be back in car this weekend.
On the plastic cover for the belt drive there is no gasket. It is not sealed
jellis
Post by jellis »
im looking for the gasket that goes between aluminium plate and the block.
cast aluminium plate is bolted to block, plastic cover bolts into aluminium plate.
The fuel pump bolts to the cast aluminium plate.
What stardog linked me but for belt driven motor not gear.
holden said no, the one i got in my gasket kit was to suit gear driven and it leaks.
Book does suggest a gasket but no picture of it maybe sealant is the way to go
if you look at the page there is some writing with 4jg2 click on that and then gaskets and seals it shows a gear drive timing gasket might be the 1 your after.
You may find this helpful. In New Zealand these parts can be obtained through the Holden Dealer Network.
From memory this gasket is sometimes metal on some models.
turnturn is right they are metal gasket because mine leaked water in the Mu before it got a rebuild that muvit got done before I bought the wizard off him.
