Vacuum lines
Vacuum lines
Hey guys, I know there is few a posts about this but would anyone have photos or English diagrams of the vacuum line setup on a 1992 mu 4jb1t belt driven. I got the car dismantled and I’ve repaired the engine and reassembled everything. The dramas I have is the vacuum lines and the tacho isn’t reading correctly. Any help would be appreciated.
Re: Vacuum lines
To get it running you only need the line from the intake to the top of the fuel pump. This is the boost sence. and the vac lines from the back of the alternator to the brake servo and for now block the other side. This should run to the solinoids by the air cleaner which control the fast idle and emissions gear but these are optional
Re: Vacuum lines
Yea ok, I’ve some how already achieved intake to fuel pump and I’m pretty sure I’ve got egr plumbed correct but I want to make sure I’ve got the waste gate and it functions done correctly as it’s not registered and want rwc to sell.
Re: Vacuum lines
wastegate is a short hose next to the turbo. The hoses we havnt fitted run things like cold start etc which isnt needed where you live
