4jg2t harmonic balancer
stardog
Post by stardog »
Has anybody had a crankshaft pulley-harmonica balancer slip like the 4jb1t does and puts the timing marks out im after a new 1i found 1 in Auckland but they wont ship to Australia unfortunately.
I cant get 1 for the belt drive engine has the 4 12mm bolts over here anywhere anybody know some where else in NZ that posts to Australia.
Cheers Stardog
Re: 4jg2t harmonic balancer
Its the big bolt in the middle that comes loose causing this. There are several parts involved and sometimes the keyway on the crank ends up worn. You will need the spacer with the keyway and will need to inspect the crank. The pulley with 4 bolts is probably ok.
Try 4x4isuzu.com for the parts second hand They may have an engine that can be dismantalled. Otherwise new parts
stardog
Post by stardog »
Its the pulley with the 4bolts that has spun about 1inch geeves the crank itself and bolt are ok I was wondering why I couldn't get the timing spot on of the marks on the pulley.
It was only that I had crap inside the timing belt cover and decided to change the belt and clean it out just to be safe I seen what had happened.
When mine did that it was the spacer behind not the pulley. On mine the pulley started hitting the timing cover wearing a hole in it (the noise alerted me to the problem) Tame mechanic said check the big bolt is tight. I said You mean the bolt thats meant to be in this threaded hole.
stardog
Post by stardog »
The big bolt needs to be torqued around 154lb if I remember right.
The big bolt is fine on mine its the pulley with the 4 holes and a rubber ring has moved no wobbles or anything just the out ring with timing marks on it has spun.
I'm trying to find a way to get a new one sent over from NZ my automotive in Auckland will only send to NZ address.
Jai78
Post by Jai78 »
Hello "Stardog" Get your parts here at > steven@isuzupartsspecialist.co.nz - http://www.isuzupartsspecialist.co.nz/
This guy post to Australia he can be reached via: 0011 64 09 274 1249
CONTACT
9 Lorien Place East Tamaki Auckland 2013
https://www.google.com.au/maps/place/9+Lorien+Pl,+East+Tamaki,+Auckland+2013,+New+Zealand/data=!4m2!3m1!1s0x6d0d4c6cf4d2f051:0x4dfac03451e11d82?sa=X&ved=0ahUKEwjroLiWyIrcAhWLVrwKHR8zBmQQ8gEIJjAA
For new parts for Isuzu Bighorn import vehicle with the ID to: info@jp-carparts.com
stardog
Post by stardog »
Hi jai thanks for the links I will give them a try in getting a new balancer sent over.
I tried a few places in NZ but they had second hand ones but not new ones.
Cheers Stardog
Jai78
Post by Jai78 »
stardog wrote:Hi jai thanks for the links I will give them a try in getting a new balancer sent over.
Cheers Stardog
If your car is an Import from Japan then email> info@jp-carparts.com They make to order if they don't have any in stock. I get new parts all the time there. If i need Electronics. Other than that i goto > [url]steven@isuzupartsspecialist.co.nz[/url] - http://www.isuzupartsspecialist.co.nz/ Call: 0011 64 09 274 1249
