whats the 4jh1 engine from did it bolt straight in and what pump did you use
will I be able to use my manual 4jg2 pump and injectors manifolds and turbo set up ??
whats the advantages of using this engine ??
New 4jh1 engine
Re: New 4jh1 engine
Got the engine out of a 06 4x4 rodeo, injector pump is custom built but was out of a 4jb1-t, you could say it bolts straight in with alot of work, no real advantage as such I just wanted to be different and see what 1 could handle, running a water intercooler, external oil cooler and water meth aswell now
Re: New 4jh1 engine
would a 4jg2 pump and stuff work??
my 4jg2 has mud its self looking at options rebuild or replacement or do i go 2.8??
Re: New 4jh1 engine
My numbers 022 6664 764
Re: New 4jh1 engine
Hi rob, care to share details on adjusting bolt for pintle ?
Cheers, Gaz
Cheers, Gaz
