New 4jh1 engine
New 4jh1 engine
My new 4jh1 engine I've been building for my Swb bighorn
Re: New 4jh1 engine
I like your wall mounted engine stand
Re: New 4jh1 engine
Wall mounted engine stand? It's on a trolley
Re: New 4jh1 engine
Its a quirk of this forums software. If you take pictures with a camera which is aware of which way up it is ie cellphone camera the image has metadata which tels it which way it should be. Thats all well and good and means that all image viewers and even regular browsers show the picture the right way up. However this forum software doesnt read the metadata so as the picture was taken with the camera on its side it shows that way unless you click on the picture so it displays only the picture.
There are a few other nasty tricks to watch out for in cell phone pics. If my guess is right I will explain them in a pm. Its an answer you might not want on the forum.
Re: New 4jh1 engine
At first I thought it was a john deer motor with all that green paint on it.
So how long before you install it in the truck.
Re: New 4jh1 engine
Yes it is john deere green, will be fitting it in 2 weeks have a 3 day 4x4 trip this weekend coming so last outing for the 2.8, will be a Smokey beast with a bit of luck
Re: New 4jh1 engine
Well I got time today and new engines in truck has abit of a ruff idle with custom injector pump but it pulls very well and is quite
Re: New 4jh1 engine
Is the bolt on the top of the boost compensator so you can adjust it on the fly?
Re: New 4jh1 engine
Yeah instead of taking the top off the pump and twisting the pintle in the pump
Re: New 4jh1 engine
Well after doing cv boots and brakes this morning, took it for a road tune 28psi of boost and 1 1/2 turns on the fuel screw it goes like it should and nice black smoke everywhere :D
