EGR Valve location - Isuzu Trooper 2800 Turbo
ABTJ1
Post by ABTJ1 »
Hi there,
I have a LR Defender with an old style Isuzu 2800 turbo in it, (intake manifold is 4 separate pipes) if that helps, and I’m struggling to find the egr valve? I can’t tell if I’m blind but I’ve been told that it definitely has one.
Any help would be great,
Many thanks,
Antony.
Re: EGR Valve location - Isuzu Trooper 2800 Turbo
It might not. The gear drive 4jb1 engines dont always. There should be 2 valves on the inlet manifold that connect to a pipe that goes across the engine to the exhaust manifold. If its not obvious it isnt there. Is there a place on the manifold that looks like it was cast ready for machining? If so thats where it would be if it had it. Is there a plate bolted to the manifold and another on the back of the exhaust manifold? Thats where it should be
