charging
seeulata
charging
Post by seeulata »
so put in new alternator new starter motor changed the charge relay battery at 14v put bat in truck run it test battery running volts at 11.7 so not charging recheck battery truck turned off battery reading 12.5v battery keeps truck going for a couple days then need to charge battery but in saying that battery still reading 12.5v before recharging so do u think it could be faulty alternator. When i put new alternator in it was fine for a couple of weeks now this any help be great Isuzu wizard 4jg2
Re: timing light
seeulata
running boards
Post by seeulata »
Did the 97 isuzu mu wizard ltd come out with running boards
seeulata
electrical
Post by seeulata »
so have problem went through water dash lights came on and stayed on so put in new battery new alternator new charge fuse and they are still on any idea where else to look. Isuzu mu wizard 1996 4jg2
Re: charging
its the charge relay you need to change Its either blue or brown. With all the water up there you may have other problems your insurer might help with
