Can anyone tell me if the diff ratio in a manual 91 mu is the same as in an auto 93 mu please.
thanks Neil
Diff ratios???
Re: Diff ratios???
The 3.1MU should be 4.3 and the 2.8 should be 4.555
Re: Diff ratios???
Thanks Dave, just didnt want to pull them out and then find out they different, i had a thought they might be.
Re: Diff ratios???
You never know if someone has changed them
Re: Diff ratios???
Easy way to tel is jack up one wheel and count the number of driveshaft rotations to one wheel rotation. Divide the answer by 2 and get the above number.
Dont know why but the 2.8 bighorn got the 4.3 diff unless it had the factory wide body kit which came with 31 inch wheels instead of the normal 29s. this is still fine even with 32s
TrooperNut
Re: Diff ratios???
Hello, I have a question. I have a coverted US Petro to a 4JGT Turbo Diesel. I have a chance to buy a 96 Limited Isuzu Trooper with an Automatict Transmission for parts. Are the 4X4 gears the same in both units. Right now I am using all BigHorn Gears from the 4X4 to the rear end.
Re: Diff ratios???
If the 96 is a diesel then it will pay to use them.
If it is a V6 petrol then there is no point.
But it is always good to have spare parts if you have room.
Diff ratios???
Hi i recently blew my front diff in my manual 5 speed 91 mu
I was just wondering if anyone knows if the 93 auto bighorns ratios are the same as? would love to find out, cheers
Re: Diff ratios???
Count the teeth on the diff. 93 bighorn could have either so could the 91 mu
Re: Diff ratios???
2.8 factory manual mu has 4.5 diffs, most 3.1 bighorns have 4.3 as the have more power so can run taller gearing
