4jh1 not rotating
kostasskoun5060
4jh1 not rotating
I believe I have a problem with my 4jh1. about the flywheel the top dead center of the engine coincides with the slot of the crankshaft sensor ????
Re: 4jh1 not rotating
Do you mean the flywheel is hitting the sensor?
kostasskoun5060
my 4jh1 the problem is that it rotates up to 3000 rpm, the DTC that shows is P1335 we changed the crankshaft sensor but nothing changed, maybe the flywheel is not installed correctly? these symptoms make us after a major engine repair
What is the description of a P1335 error code?
kostasskoun5060
p1335 Engine speed output circuit failure https://youtu.be/MuNZzVPMuUE
There is a chance that the crankshaft sensor only measures crankshaft rotational position and not RPM. There may be another sensor somewhere for RPM. Maybe in Injector pump or camshaft area.
kostasskoun5060
the crankshaft sensor reads the engine revs and top dead center. I believe it is the flywheel is misplaced the car behaves this way after a major engine repair
Only way to find out is lift the engine out again
kostasskoun5060
has the specific problem with his rodeo happened to another owner ???
