winch lube
zacco
winch lube
Post by zacco »
Hey blokes, has anyone fitted a grease nipple to the gear side of an electric winch?
Cheers, Zacco
Brinky
Re: winch lube
Post by Brinky »
Hi Zacco. Is your winch a Runva? If it is please let me know if this mod works. Wonder why they don't fit grease nipples from new.
Re: winch lube
Adding a grease nipple wouldnt deal with any water that got in. Also you dont fill them with grease only giving the parts a good coating. A quick google came up with a guide
https://www.whichcar.com.au/gear/recove ... -4x4-winch
zacco
Re: winch lube
Post by zacco »
Hey runva, mines an ironman winch
Brinky
Re: winch lube
Post by Brinky »
They say the best way to make your winch last is use it heaps. Mine gets plenty of use as I'm always getting stuck trying to follow those big trucks. I just wish I had bought the faster winching model.
mudslinger
Re: winch lube
Post by mudslinger »
to much grease can make it really hard to pull out on free spool. few people have said to get rid of all the grease and run atf in there.
tonkamu
Re: winch lube
Post by tonkamu »
I got the same runva 9500 xs winch, I rang runva once and they said u don't have to do anything?
mudslinger
Re: winch lube
tonkamu wrote:I got the same runva 9500 xs winch, I rang runva once and they said u don't have to do anything?
overtime water and crap can get in. strippping it down from time to time and re greasing needs to be done unless you want it to work the one time it needs to?
