Holden rodeo suspension will it fit?
mrMUMU
Post by mrMUMU »
Looking at doing a full rebuild on my Mu. Has anyone used this suspension kit or something similar that would be interchangeable
https://rover.ebay.com/rover/0/0/0?mpre ... 1727777020
Re: Holden rodeo suspension will it fit?
I think the early jackaroo is the same as MU. Rodeo has heaver rear springs and longer torsion bars
This has come up so often. Jackeroo springs are too short and the ride is terrible plus the risk of inverting a shackle.don't know if rodeo fit but my guess is a 90ish model should be the same. Get the eye to eye measurement and compare it to how yours is sitting now. If the shackle has to be vertical or less to fit or if its past 45deg back then you need different springs
mrMUMU
Post by mrMUMU »
Ok great thanks for the reply. I better do a bit more research
tonkamu
Post by tonkamu »
I have lovells lifted springs with 90mm shackles. Has no sagged in 4 years, best springs I've had but only con is they are fricken hard like a flatbed ute over bumps.
take a leaf out of the pack to soften them
AusZuMu
Post by AusZuMu »
In case it's useful info for anyone.
A couple of weeks ago I fitted Tough Dog 45mm lift leafs meant for pre 97 TF Holden Rodeo and they are a perfect fit.
Wazza556
Post by Wazza556 »
I installed a Fulcrum kit on my 1993 Mu.
Fitting was easy and fitted like a glove.
Gave me 60mm lift in the rear.
https://fulcrumsuspensions.com.au/holde ... 0227832885
