93 Bighorn Central Locking Connector and Window Cable Bracke
If you need something post it here and maybe someone can help you out
saunderson
Post by saunderson »
Just wondering if anyone can point me in the right direction to find the small plastic connector that connects the left rear door lock wire to the central locking motor unit? It's just a tiny piece of plastic that clips onto the end of the wire and then clips around the wire that moves in the central locking motor?
Also trying to find the plastic bracket that holds the top end of the electric window cable that lifts the window up? I.e. the sheathed part of the cable comes out of the top side of the electric window regulator inside the door then clips into the bracket i want before the unsheathed part of the cable goes down the door. Again for the same left rear door.
