95 bighorn electrical issues
Colinjrose
Post by Colinjrose »
My 95 bighorn has a couple of problem.
Stabi light stays on. It changes brightness a little between when it's on and off but remains in all the time
Also power windows only work intermittently. Rear demis t and mirror dentist dont work.
4wd light stays on and timing belt light is on.
Any help would be helpful.
Re: 95 bighorn electrical issues
Stabi. Start by seeing if the rear swaybar release is locked or open
Windows and demisters is a matter of working through with a multimeter. First thought though is the charge relay although that would see the alterbnator light on as well
4wd light depends on whether you have to axle lock on ther front diff or free wheel hubs. Could be either in that year. If =you have free wheel hubs the light is controlled by a light on the gearbox. If you have the diff with the assembly on the left side the switch in the gearbox activates the lock in here and once it locks the light comes on. Its vac operated
timeing belt light is controlled by a jumper on the back of the speedo. Once you have done the iming belt move the jumper to the other holes
