Looking for a upper right wishbone to suit 95 wizard with good bushes.
Andy
Wizard upper wishbone
Re: Wizard upper wishbone
If its only the bushes needing doing you are better just getting them done. You need a big press to get the old ones out so not every garage can do it. If you go poly buses they are easy to put in but wont last as long if used off road. Poly also squeaks.
