Need help my truck was efi and now been converted to machine
Shaneo12379
Post by Shaneo12379 »
Hey there guys and girls so I got a little problem I had my isuzu wizard 4jg2 changed from a efi pump to a manual one and being auto it had a few problems now when I put it under load towing the boat it not changing gear and it's flashing trans lights
Re: Need help my truck was efi and now been converted to mac
tps not set correctly. I would be surprised if a 96 wizard had efi????
A 96 wizard should be mechanical pump to start with unless its be changed at some stage or maybe the transmission is getting to hot towing do you have a after market trans cooler on it but like geeves said could be tps set wrong on it.
I have a after market trans cooler on my wizard and tow a 2 ton trailer and don't have any problems with it changing gears or trans lights on the dash.
Shaneo12379
Hey guys very sorry it's a 1998 and was a efi pump I have put a 2.5" exhust and 3" Air intake and 3" stainless steel snorkel also running a 4jx1 turbo and now done a mechanical pump and the gearbox not changing under load
do you have kick down cable connected to I injector pump from the gearbox I don't know how the efi system is set up never seen one myself everything in Australia is 90-96 mechanical injection pumps.
why did you lose the efi pump?
On the manual pump models the auto uses an ecu for speed control and not much else. gear changes are governed by tps voltage kick down cable and a speed pulse sent from the speedo. Later boxes had a full ecu doing everything but I dont know if this happened during the 4jg2 life cycle. Check the adjustment of the tps with a voltmeter check the adjustment of the kick down cable and hopefully things will be fixed
mudslinger
Post by mudslinger »
shane, the trans ecu needs a feed from the speed sensor which goes via the gauge cluster to the ecu. if the trans ecu isnt getiing a signal then it will cause your lights for the trans to flash and it wont change up past 3rd gear. what have you or gav done to it lol
Shaneo12379
Haha how did ya no gav did it. And it seems to be runing good now . It go in all the gears now . Still have the light flashing . But I had to adjust the tps a few times till I got it right but the only thing now is she u start it from cold or sitting for a wail it puffs out white smoke and misses for about 30 secs I going to look at getting it tuned soon by repowers
mudslinger
i know everything haha, white smoke not good tho
Shaneo12379
Text me 0278411614 have a wee chat about it
