Dear my Isuzu Colleagues;
During a lot of time I try in my way to arrange and put in order my Isuzu Trooper, UBS55, 4jb1-TC (2.8TDI), 1990
Last week, I checked that the brake lamp (dashboard) remains lighting and I stat to investigate which sensor was falling
I checked the level hydraulic fluid, is ok
I checked the hand break switch, is ok
And then I check the servo brake system (vacuum hose), and I discover that the sensor located in this area is out of work. The vacuum seems ok. When I take out the cable, the lamp in the dashboard switch off, if I put again the cable, the lamp switch on
I understand that this sensor / switch works with the vacuum, but is damage
My surprise is when I check the mechanical suppliers, nobody knows this sensor: Mitsubihi, Toyota, Nissan, Land Rover, Bosch, Faes…
Can anybody to help me to find this? And his name? Because I try to find in aftermarket suppliers, but only I can find the oil pression sensor
Best regards;
P.D. How I can insert the picture???
