LWB Springs and Shocks
bhavler
Post by bhavler »
Hi All
Can anyone confirm the amount of lift you get if you put in LWB shocks and springs into your SWB Bighorn. Is it worth doing until I can afford a new set?
Re: LWB Springs and Shocks
Mine went up 20 or 30mm butreally that only restored original height as both sets were sagged. Very easy to change and I might be able to give you a set if you want.
When you are ready for new springs I got Cobra Springs from SAS Autoparts in Petone matched to some Ultima shocks. They do raised and extra raised. Stick with the raised as the extra raised are a little much for the swb and Ive been chasing a vibration ever since
