4JX1 Wont Start
MRFMXAUS01
4JX1 Wont Start
Post by MRFMXAUS01 »
Gday all i have a jackaroo with the 4JX1 motor and it wont start any ideas i have been searching and found some people saying it could be the oil rail sensor or the other oil sensor on the side of the motor i guess i should change them and go from there cheers all.
elduderino
Re: 4JX1 Wont Start
Post by elduderino »
Hi there. I had the same problem and after changing the oil (5w synthetic or semi-synthetic), oil and diesel filters, a new Varta battery ($369 on special) and replacing the glow plugs, it still wouldn't start. I got it going last night after changing the fuel rail oil pressure sensor! I used a $60 generic one that claims it is more reliable than the original, (as opposed to the $350 Isuzu one) off Trade Me. It took me around 2 hours to complete the fit and have it up and running again.
Re: 4JX1 Wont Start
Yes that would of been the next guess. Havnt heard of many of those sensors failing but the next options are expensive. Have a check of the wiring loom though. Any sign of oil getting into the loom change it. If the oil gets to the ecu its a very expensive repair
