2.8l gearbox
mrmunz88
2.8l gearbox
Post by mrmunz88 »
can you match a 3.1 l manual gearbox to a 2.8 engine or do i have to find a 2.8 one as are proving quite hard to find one?
Re: 2.8l gearbox
Only problem is they have different outputs so either change driveshafts or tail shaft section
mrmunz88
Re: 2.8l gearbox
Post by mrmunz88 »
so if i used a 3.1 gearbox i change the diffs to and that would sort that out?
Re: 2.8l gearbox
no need to change diffs. The rear driveshaft on the 2.8 has a spline into the gearbox. The driveshaft on the 3.1 has a flange similar to the diff end of the driveshaft and a spline in the front section.
If you swap the outputs on the gearbox or swap the driveshaft (easier option) then you are fine
mrmunz88
Re: 2.8l gearbox
Post by mrmunz88 »
sorry if i dont follow you but all i have todo is use the 3.1 driveshaft out of a mu and all will be well with the 3.1 gearbox does every thing line up reguarding the bell housing as i have herd storys that it wont?
Re: 2.8l gearbox
not aware of issues. Some people have changed flywheel but that was for the bigger clutch
Re: 2.8l gearbox
will have to make a new gearbox cross member aswell
Re: 2.8l gearbox
This is manual to manual I believe
Re: 2.8l gearbox
When I changed engines in the mu from 3.1 to 2.8 I used the 2.8 clutch and fly wheel that was on the donor engine no problems so far.
