4JB1T overhaul questions!
MrWho
Post by MrWho »
Hi all!
I have an Isuzu 4JB1T engine fitted to a Land Rover 90, it has run fairly well and I really can't complain about it.
Recently, it has shown symptoms of a worn clutch disc, so I am planning to get out the whole engine a do some refreshing (it could include a major overhaul, just for the sake of peace of mind).
So, here comes my question: the engine has a turbo fitted from factory, but I would like to improve it with an intercooler (I already got the proper intakes and piping from an intercooled version of a similar engine, to modify it), is the upgrade just a straightforward one or should I worry about getting stronger pistons, a different fuel pump or injectors, that kind of things?
Thank you very much in advance!
Cheers!
Re: 2JB1T overhaul questions!
internals on the intercooled and non inter cooled are the same
MrWho
Re: 4JB1T overhaul questions!
Post by MrWho »
Hi Geeves!
Thank you very much! Every time I get more convinced that a full overhaul is the best option here (self indulgence, maybe? ;) ).
I'll start collecting the bits needed before removing the engine and dismantling it.
Cheers,
LB.
