4jb1 vnt
00quattro00
4jb1 vnt
Post by 00quattro00 »
Has anyone fitted a vnt to a 4jb1? I have a gt2260v and a gtb1756vk i can use. At what stage will it start running out of fuel? If i can have near 400nm ill be happy
sanramonrover
Re: 4jb1 vnt
Post by sanramonrover »
I take it your question is aimed only at the erudite elite of this list :ugeek:
How about translating those acronyms into English for the rest of us. :roll:
I have a 4JB1 but wouldn't know which end to look at for those other bits and pieces. :?
Don't leave us plebeians in ignorance please. ;)
Re: 4jb1 vnt
At a guess Garret turbos?
The motors strong enough but modding the fuel pumpfor more fuel and dealing with EGTs are the issues
00quattro00
Re: 4jb1 vnt
Yes both garret turbos, the gt2260 is from a bmw 3.0l and the gtb is from a landrover 2.7.
What size plunger and injector nozzles do they have? At what boost levels does the head start to lift?
Re: 4jb1 vnt
Are the turbos normal wastegate operated or variable vain? plunger is 10mm no idea on injectors, boost doesnt kill diesels fuel does, i have run 25psi in a 4jb1 factory turbo engine
Powertruck95
Re: 4jb1 vnt
Post by Powertruck95 »
the gt2260v is vgt ive looked into doing a similar setup notx
with this particular turbo but similar. the problem you need to overcome is controlling the vgt mecanisim you can either use vaccuum or electronically control them. the theory behind vgt is good minimal lag with a variable a/r ratio allows the engine to breathe better without choking. would have to re calibrate the fuel system as you would have more air available earlier in the rev range which would help drive gets down
jellis
Re: 4jb1 vnt
Post by jellis »
I will be upgrading to a gt2259, supposedly it should be a perfect fit.
I am interested in how you go with the vnt though, mainly how you will control it.
00quattro00
Re: 4jb1 vnt
jellis wrote:I will be upgrading to a gt2259, supposedly it should be a perfect fit.
Just going to use a dawes valve. Had thought about making a controller but id rather stay away from electronics on this particular setup
