wheel bearing screws
shane0nz
Post by shane0nz »
hi guys how common are the 3 small front wheel bearing screws for the adjustment ring, anybody know if i will find replacements at say repco? otherwise ill take the ring and lock washer and hunt around for a match
Re: wheel bearing screws
I replaced mine with Socket Head Countersink Screws. M3 or M4 from memory.
just a standard philips screw. Will trust Rob on the size Shouldnt be an issue at an engineers supply shop. They can be a pain to undo if you dont have the exact fitting screwdriver. I like robs idea with allen heads but possibly would of chosen torqx in prefference. Either way make sure you have the right driver head in your toolbox
shane0nz
Post by shane0nz »
Sweet guys thanks and yes great idea changing heads too
shane0nz
Post by shane0nz »
yep M4 looked everywhere luckily found 25mm length hex at 1 engineering supplies and had to trim back, cheers
