Injector Poistion
Injector Poistion
Isuzu 3.1 Bighorn 4JG2 Turbo motor injector are directional I'm not sure about where the mark on the Injector lines up with , I not found anything in the Manuel about either There is something shape like a comma does the Injector line with that, there are only 3 of those comma shape in the head with a Head bolt in them as well , Just want to be sure
Re: Injector Poistion
These photos should help you out but I forget what torque you do them up to.
Ok Thanks the Guy that service them must given me not so good info Thanks for the Pictures Cheers
I think the torque setting in Ib ft is 43 -50 from I see in the book
I think it is 47lb torque for the injectors.
