FAQ - Isuzu Body lift
In here you will find answers to commonly asked questions about verious modifications. You will also find some great DIY\'s for doing mods to your Isuzu. If you have a mod to add here
Isuzu Body lift
MU-BIGHORN-JACKAROO swb
10 blocks
6x 10mm grade 8.8 bolts & nuts
4x 10mm x 1.25 grade 8.8 bolts
MU WiZARD-BIGHORN-JACKAROO lwb
12 blocks
6x 10mm x 1.25 grade 8.8 bolts
For up to a 2” body lift the fan shroud needs to be cut and the gear sticks should be bent so the boot stays in place or a spacer put under the gearbox mount
For above a 2” body lift steering shaft, gear sticks needs to be lengthened, break & clutch lines may need to be replaced or moved, radiator & shroud need to be lowered
Pissy
Re: FAQ - Isuzu Body lift
Post by Pissy »
I hope Pig does not mind me posting this Brief procedure written by Dasnoboarder
• Take Front bumper off before starting
• Seatbelt retention bars removed and lengthened (may not need to do)
• Release firewall clipped lines (may not need to do)
• Loosen fuel filler hose clamp (may not need to do)
• Loosen steering shaft from firewall to steering box & steering wheel
• Loosen all body mount bolts, remove only one side
• Jack up the side of body with bolts removed & insert blocks on top of rubber mounts
• Insert new bolts loosely to this side
• Remove bolts of other side
• Jack up second side & insert blocks on top of rubber mounts
• Clutch master cylinder has had to be moved in the past (may not need to do)
• Check fuel filler & tighten clamp
• Check breather hoses
• Check handbrake cable from firewall not stretched too tight
• Check clutch hose not stretched too tight
• Check brake lines aren’t stretched too tight
• Gear levers will foul, rubber boot creates issues, need to bend/cut & weld
• Tighten bolts
• Radiator ideally needs to be dropped to match body lift, or electric fans installed.
• Go through in reverse and reattach everything & tighten things up
