Wizard problems
jackabea
Wizard problems
Post by jackabea »
Hi All
New to the Forum looks good and very helpful, I have a RHD 1995 Wizard and all the windows have failed and the central locking has stopped working, now i am told there is a relay which controls these but i can't identify it, i know there is a set of four relays in the drivers door pillar and some in the fuse box under the bonnet, but as my truck is a jap import and everything is in Japanese it makes things a bit of a pain in the rear.
Can anyone shed any light on how to locate this relay?
Many thanks
jack
Merry Christmas and a Happy new year to all
Re: Wizard problems
Welcome to the forum jack I also have a 96 wizard and a 94 MU.
These diagrams might help you out there is 1 for under the bonnet the other fuse box is the 1 you see when you open the drivers door the 4 relays in the kick panel im not sure what they operate but change them around to different positions and see if that helps.
jackabea
Re: Wizard problems
Post by jackabea »
Thanks for the info, i will go and play when the weather improves and let you know how i get on, Cheers. :D
