Body lift 2000 mu 4jx1 3lt
Onlymuwilldo
Post by Onlymuwilldo »
Hi I'v been doing alot of reading about lifting truck but still a little unsure about what im going to have too do regarding the steering rack .. 50mm body lift any information on this and anything else i should know before I start would be greatly appreciated cheers...
Re: Body lift 2000 mu 4jx1 3lt
Does yours have rack and pinion steering?
There are very few modified Mus of your model around so a lot of stuff might not apply although I expect only the steering should be an issue. On the earlier trucks they had a steering box mounted on one chassis rail and a body lift sometimes required a lengthened shaft and a lot of those done were not to wof rules regarding welding steering components which is quite forboden. On yours the steering input shaft will be longer and a better angle so you have a fair chance of getting away with it but a few photos will help if you need to extend it somehow
Onlymuwilldo
Cheers geeves thats grate thanks for advice still in planning stage at moment but have 50mm lift kit and a snorkel on way from up east somewhere finding it hard to pin people down on what will and will not fit this thing as ya said very few of these things modified (why i so keen to do )
