G'day all
Long suffering Bighorn owner, can any of you guys and girls recommend anyone in Hastings area that likes to do the odd perky...I've a small coolant leak up somewhere near the alternator
Would love to have a stab at it myself but lack of knowledge and tool prohibits it..
cheer in advance
Terry
96 3.1D 4jgt2
Perky anyone?
Re: Perky anyone?
90% chance its a hose
2 most likely options are the 2 hoses on the turbo or the bottom main hose
The bypass hose between the water pump and thermostat housing is also possible
Re: Perky anyone?
I had a good look around and the hoses that I can see all look ok, there is some pooling of fluid on top of the crankshart housing, immediately under the water pump, under the water pump though is dry, I think it could be a gasket perhaps that not sealing, would the pully/crankshaft housing have a gasket that would/could leak coolant?
Bottom of the same housing seems to ooze ever so slightly too.
cheers
cheers
Re: Perky anyone?
no but the thermostat houseing does Also the thermostat housing to head does pluss there is a small hose in there well hidden from view and the top hose. Then there are 3 or 4 sensors but they rarely leak
