rear end lift on mu
macca81
rear end lift on mu
Post by macca81 »
hey there does anyone know were to got extended shackels made or set up from in wellington
also wat r other ways of doing the lift
cheers
slightlydodgy
Re: rear end lift on mu
Post by slightlydodgy »
Depends on the lift you want. New springs with a bigger arc will give you more gain than shackles Mine were 200mm and only gave about 50mm lift. Geeves I believe knows where to go in Wellington
most suspension places can get replacement springs. Repco used to have a good deal but dont know now. Try Autolign or hutt city auto parts or bnt
macca81
Post by macca81 »
thanks will do
Rodeovic
Post by Rodeovic »
Cant you modify the diff to fit underneath the leave spring,you gain roughly 200 mm.my dad did it on his land rover
slightlydodgy
creates a whole lotta issues with keeping it road legal. You also run into issues with pinion angles and driveshaft length. If you sort that to gain the same lift at the front you would be talking major modification probably an sas. Landys already have leaf springs all round and are mechanically fairly forgiving
MrRevhead
Post by MrRevhead »
Yep Autolign in Petone would be a good place, they are part of BNT but focus on suspension.
I think G Guy motors in Thorndon are local 4wd experts.
Could also try Archers springs in Rotorua or Bellamys in Chch for a new set of raised leafs.
Don't forget you will quite possibly need new longer shocks as well
ThomasT
Post by ThomasT »
4wdbits.co.nz they are an awesome nz site for all gear. they have rear shackels for $200.00 i think, may even be cheaper.
