Around 12 months ago I bought a 2000 Jackaroo (Bighorn, Trooper) with 4JX1 3.0 diesel. The engine had typical issues and with some help from this forum I ended up fitting a 4JB1 2.8 turbo diesel engine.
I have now documented the job and am making it available to anyone else who has found themselves in hot water with a Jack/Bighorn/Trooper and needs to ressurrect it. Send me a message and I'll arrange to send it to you in PDF form.
4JX1 to 4JB1 Jackaroo/Bighorn/Trooper conversion
jackdriver
Re: 4JX1 to 4JB1 Jackaroo/Bighorn/Trooper conversion
Im sure this user would like a copy
viewtopic.php?f=25&t=3758
Also if you email it to isuzunz@gmail.com it will be easily available to everyone thanks
maciejewskiwaldek
Babafather
Send me please a copy at nbigomokero@ymail.com in PDF form
Roderunner
I tried contacting you via the pm feature but didn't succeed, could you please send a copy to ---------com. Thanks in advance!
Babafather
Thank you for the copy. But just want to know...Between a 4JG2 Isuzu engine and a 4JB1 one, which can be easily swapped in a 4x4 Isuzu Wizard 4JX1 turbodiesel with manual transmission ?
4jg2 or 4jb1 are going to be the same amount of work have to change g-box aswell as bellhousing is different
Could I please have a copy of the PDF?
Thanks.
Thanks.
I am new here i have just bought a 1999 isuzu bighorn which had a 4jx1 the previous owner had swapped the engine and fitted a 4jg2. The problem i have is there is no power at all could you please send me a copy of the conversion there could be something i am missin thanks
viewtopic.php?f=19&t=2334&p=20398#p20398
might help a few people
