Unknown warning light on dashboard
bkkmick
Post by bkkmick »
Hi
I have a 2009 MU7 (Thailand).
Recently I noticed that, if I'm accelerating up a hill, a warning light comes on. This light looks like the fuel low warning light but it's in the centre panel and has a number of vertical lines underneath it.
I've tried googling around for help on what that light means but to no avail.
Anyone got any ideas?
Thanks
Mick
Re: Unknown warning light on dashboard
Hi
Yours is the first Mu7 here. Welcome aboard. We would love to have a few pictures at some stage.
Is the light you mention in the picture below? (this is from the 96 version of the same vehicle)
bkkmick
Post by bkkmick »
Couldn't embed an image as I got the error message "It was not possible to determine the dimensions of the image."
Hope these work...
http://www.fastcarhire.co.uk/FrontView.jpg
http://www.fastcarhire.co.uk/RearView.jpg
http://www.fastcarhire.co.uk/Inside.jpg
http://www.fastcarhire.co.uk/Dashboard.jpg
The light I don't understand is the yellow one above the engine light.
Thanks again...
Mick
slightlydodgy
Post by slightlydodgy »
Looks like the fuel light to me How full is your tank when this problem occurs and does the fuel gauge move when you go up the hill as well?
bkkmick
Post by bkkmick »
I have a fuel tank light in the right hand circle that appears when fuel is low. This one is separate. They look the same apart from the vertical lines below the pump.
Weird, I know.
In my picture in the strip of lights at the bottom from the left you have fuel, timeing belt, check trans and then a light for the water separator in the fuel filter. Do you have this light? Does the light you have mean the same thing?
Try draining the drain on the bottom of the fuel filter. This is a guess
Re pictures We have blocked pictures hosted elsewhere due to problems with them disapearing some time after the post leaveing information missing for future readers. Use the upload attachment button below the reply window to upload direct to the site. There is a maximum size for the picture.
I think the D-Max has the same dash. There are a couple of members on here with them. They might know
They also have a fuel heater near the tank it might have something to do with that
bkkmick
Post by bkkmick »
Thanks for the suggestions guys. I reckon that maybe I'll head down to an Isuzu garage and practice my Thai. Should be interesting!
I'll let you know what they say.
4JG2WIZARD
Post by 4JG2WIZARD »
Hi i have a 1996 wizard, when i turn key on the airbag dash light flashes 6 times then turns off then when truck starts it does the same, what does this mean.
96 wizard don't have airbags that I know of mine don't have them.
