4HE1 Diesel motor in a 1998 Isuzu Wizard (Rodeo) Petrol(gas)
All Club management, news and development discussion
Forum rules
* Above all, play nice
comanology
Post by comanology »
Hey, Can a 4HE1 Isuzu Motor fit in a 1998 Isuzu Wizard (Rodeo)? The 4HE1 is out of a Isuzu NPR. Does anyone know of any trouble vise the computer issue which will be solved by intalling the NPR computer. Does anyone know of someone who has done this before.
Re: 4HE1 Diesel motor in a 1998 Isuzu Wizard (Rodeo) Petrol(
http://forum.ih8mud.com/diesel-tech-24- ... -swap.html
The above might help.
Thats a very big engine and very low reving. I can see it hitting the red line at the speed limit with 4.3 diffs and 35 inch tyres. However it will climb anything you point it at
A 4jh1 would be a better bet
comanology
This is the NPR
http://www.isuzucv.com/nseries/n_photo.html
or what about the 4HK1-TC
Engine Isuzu 4HK1-TC turbocharged intercooled diesel
-Displacement 5.2 L (317 in.3)
-Engine Power 215 HP @ 2,500 rpm (A/T), 195 HP @ 2,650 rpm (M/T)
-Engine Torque 452 lbs./ft. @ 1,850 rpm (A/T), 387 lbs./ft. @ 1,600 rpm (M/T)
-Oil Level Indicator Dash-mounted oil level check switch and light
http://www.isuzucv.com/nseries/nprdieselspecs.html
http://www.isuzucv.com/images/van_snow_mountain.jpg
A tape measure will probably tell you it wont fit.
Those big engines are heavy and slow reving. A 4jg2 revs to 4k This is a common Frontera motor $jx2 is the same. Your 4h range of motors all have red lines below 3k
Not impossible but I see big problems fitting it, upgrading the suspension, Trying to go round a corner etc
