PLEASE, PLEASE, PM me with new part numbers and where you got it if bought new (Holden, supercheap, Repco etc) and a price too.
If any thing is incorrect please PM me as well.
This section will only get better if forum members help out with the info.
Trust me when I say that "you'll" need this FAQ to be as big as possible with as much information as possible.
ALSO please note that any/all prices are not "up to date" as this list has been growing over 5 plus years.
PARTS from a maintenance on 1990 Isuzu mu (4jb1t) (thanks to Demonic)
I have included this small sub section of parts nummbers for the 1990 4JB1t due to Demonics most recent jobs,
it appears that the 1990 model may need to have need its own sub section for parts
Clutch slave: SR-G173 (From BNT)
Air Filter: LA1506V (From BNT)
Alt/Fan belt: BOSCH 15A1030 (From Supercheap)
Cambelt Kit: Dayco KTBA 157 - Contains 1xCambelt, 1xTensioner, 1xIdler, 1xOil Seal Kit (has 3 seals inside) (From BNT @ $310)
Oil Filter: FRAM PH5190 (From BNT)
Lower Balljoint: 89-90 Trooper SBJ282 (Repco)
Nolathene Shackle Bushes: N47003 (Repco)
L/H Brake Cable: G*8970153030 (Genuine Holden)
Rear Brake Pads: TRW GDB768 (Does L/H+R/H) (Repco)
Water Pump with Gasket GWIS-25A (GMB brand from Repco)
Tridon Thermostat - TT326-180 (Repco)
Tridon Thermostat Gasket - TTG9 (Repco, inside hole is slightly smaller than normal one but does work)
Other 4JB1T parts numbers list
Just a note... I think some part numbers in aus may be different to parts in NZ
4jb1 Engine Australia rebuild kit ................ES-ISU20R1 (does not have belt drive timing cover gasket or cam seal)
4jb1 Timing belt No................................. T966 Gates
Air Filter..............................................HDA5767 RYCO, A316PA5045 Phoenix, AF25372 fleetgard
Alternators:..........................................55 Amp, 80 Amp, 120 Amp
ALT7055R or
ALT7055R-80
ALT160502 (For N series Isuzu trucks)
Brake caliper (seal) kit............................. (REAR only) The kit does both rear calipers and includes all the rubber parts plus a few clips etc. and a small amount of rubber grease. Brand: Seiken Part no: SP-M29 Purchased from: BnT (Brake & Transmission NZ Ltd) Cost: $100.88 NZD +GST (thank you gixxer for the info)
Centre link ..........................................road safe number TR890
Clutch Complete master Kit.........................K8585
Clutch fork boot .....................................Holden number 94156700
Clutch master kit ....................................PBR number K8585
Clutch pedal bush ...................................Holden number 97035885
Clutch pedal bush....................................JB1794
Clutch slave cylinder kit ............................Holden number 94058421
Clutch Slave Cylinder Kit............................94058421
Complete Clutch master cylinder................... PBR number JB1794
Complete Clutch slave cylinder.................... PBR number JB4205
Coolant Pump.........................................?
CV Boot outer........................................number 200-056 repco
CV to stub axle bearing.............................Holden number 94407708
CV to stub axle seal ................................Holden number 97123691 & 97123692
Fan & Alt Belt x1.....................................17A1055
Front axle seals .....................................Holden number 8973735550
Front Brake Pads.....................................DB1116
Front brake's .........................................bendix DB1116/4WD
Front diff pinion seal ...............................Holden number 8943185202
Fuel Filter.............................................Z304 RYCO, FC-1001 Sakura
Gear stick cup .......................................8944420990
Glow Plugs 4JB1 (2.8)................................Bosch part number GPI-010
Hand break cable left side ........................Holden number 97015300
Hand break cable right side.......................Holden number 97015303 (looks like this might the wrong part,....97015299 is being test as potenial proper part
Idler arm ............................................road safe number SX7660
K&N Air Filter for 2.8 MU.......................... E2415
k&N for a 2.8 bighorn.............................. E2220
NOTE: please measure your stock filter first and compare it the K&N web site,...there seems to be many varying sizes in air filter boxs and therefore,.. filters.
CHECK BEFORE YOU BUY
http://www.knfilters.com/search/appsearch.aspx
LH engine mount ...................................Holden number 94334159
Lower ball joint.....................................road safe number BJ282
MU Bonnet stay clip ................................8944415380
Oil Capacity.........................................Light Diesel Oil 15/40w recommended.
4.8L or 6L,.....Make sure you know your vehicles correct Oil volume, consult the user manual, check the Oil dip stick after filling, NEVER OVER FILL
Oil filter...............................................Z402 RYCO , C-1712 Sakura , NipponMAX WM0319 , Holden/Isuzu Genuine 894360421
Power Steering & Air con belt......................13A1525
Power steering pump seal .........................ap0743g & bearing 6202
PWR Strng & Aircon Belts x2.......................13A1525
Radiator...............................................?
Rear Brake Pads......................................DB1161
Rear brake's ..........................................bendix DB1161/4WD
Rear diff Crown wheel bearings ...................30210J-N
Rear diff pinion bearings ..........................front TR0608A-N, rear TR070803J-N
Rear diff pinion seal 45x78x12/25.5..............Holden number 8973286480
Rear Leaf Springs Kit ...............................As 4JG2
RH engine mount....................................kelpro MT8511
Steering Seal.........................................8-97081746-0
Steering Service kit ...............................8-970299451
Tie Rod ends/joints.................................WTE966(inner) and WTE967(outer) the Brand is WASP ,...same as 1989 Jackeroo and 1992 4wd Rodeo
Thermostat............................................Dayco DT45A
Timing Belt (match tooth type on replacement)..Gates T966 up to 1993
TurboCharger.........................................RHB5 VI 87,..or...RHB5 VI 58
Wheel bearing kit ...................................power max KWB1274
Wheel Bearing Kit....................................CBC Bearings Australia, Kit No H110K1T WBK1274, Cost $88 incl GST per side.
Rodeo TFS55.
A big thanks to harryasaboy for the following info
Rear rh hand brake cable for my Rodeo TFS55.
Got it from the UK,...."Milner Off Road" (http://www.milneroffroad.com/isuzu) for 13GBP + 25GBP express shipping(About $20AU + $38AU).
They asked for my V.I.N. and I got the correct cable. I ordered it on Mon and got it on Friday from the UK.
