PLEASE, PLEASE, PM me with new part numbers and where you got it if bought new (Holden, supercheap, Repco etc) and a price too.
If any thing is incorrect please PM me as well.
This section will only get better if forum members help out with the info.
Trust me when I say that "you'll" need this FAQ to be as big as possible with as much information as possible.
ALSO please note that any/all prices are not "up to date" as this list has been growing over 5 plus years.
Engine: 3.1TD (4JG2)
Air Filter.....................................RYCO A1388/ Uni Filter 130-200S /True Flow 10200
Alternators: ................................Best to find one that is serviceable if not then try these 55 Amp, 80 Amp,120 Amp (Hitachi)
......ALT7055R Amps ? approx 50amps NOT SERVICEABLE!
......ALT7055R-80 NOT SERVICEABLE!
......ALT160502 (For N series Isuzu trucks)NOT SERVICEABLE!
Auto service kit....................... from autobarn and the codes were WCTK43 interchangeable with FK-1692 for $57.99 and it is a cooper brand.
Ball join Uppert # BJ-203 bought from Pedders
Ball Joint Lower # PBJ282 bought from Pedders
Clutch Complete master Kit................?
Clutch pedal bush............................?
Clutch Slave Cylinder Kit....................?
Coolant Pump...............................GMB WP1100
Fan & Alt Belt x1...........................15A1030
Front Brake Pads...........................DB1270
Fuel Filter...................................Z304 RYCO. FC-1001 Sakura
Glow Plugs 4JG2 (3.1)...................................Bosch part number GPI-014 (Repco)
K&N Air Filter...............................E-2417 NOTE: please measure your stock filter first and compare it the K&N web site against the E-2417,...there seems to be many varying sizes in air filter boxs and therefore,.. filters. CHECK BEFORE YOU BUY
http://www.knfilters.com/search/product ... rod=E-2417
Master cylinder ............................JB7421
3.1 "grenade" master cyl is apparent 8-97089-677-0
Oil Capacity.................................Approximately 6ltrs Light Diesel Oil 15/40w recommended.
Make sure you know your vehicles correct Oil volume, consult the user manual, check the Oil dip stick after filling, NEVER OVER FILL
Oil filter.....................................Z402 RYCO / C-1712 Sakura / NipponMAX WM0319 / Holden/Isuzu Genuine 894360421
PWR Strng & Aircon Belts x2.............13A1525
Radiator.....................................Rodeo 97 #21031
Rear Brake Pads............................DB1280
Rear Leaf Springs Kit......................
2 x HR-15 H/D Leaf Springs
1 x LGSKISZ-004 Greasable Shackle kit
4 x UBL-18 U bolts
2 x N710021 Rear Bush kit
1 x N71506 Front Bush kit
Rear vented rotors ........................RDA841
Steering Seal...............................8-97081746-0
Steering Service kit.......................8-970299451
Tie Rod End............................... # TE210R
Thermostat.................................Dayco DT45A As 4JB1T to 94
Timing Belt (match tooth type on replacement) Gates T844 1994+
1. Timing Belt.............................. Dayco 94409 (T844) (4JG2 Bighorn 3.1TD 1994+ unsure regarding MU, best to post a question first?)
2. Timing Idler Bearing.................... GM# 8-94382-215-0 NSK# 67TB0806 (4JG2 Bighorn 3.1TD 1994+unsure regarding MU, best to post a question first?)
3. Timing Tensioner Bearing.............. 8-94382-214-0 NSK# 67TB0805B01 (4JG2 Bighorn 3.1TD 1994+unsure regarding MU, best to post a question first?)
Timing KIT .................................. NASON timing kit for a 4JG2 engine (includes belt, tensioner bearing, Idler bearing ) for $334.00 from REPCO, The part number is # vkma99004s.
TurboCharger...............................IHI RHF5 8971673342
Wheel Bearing Kit..........................NSK 4276 (late94 onwards)
Wheel Bearing and Seal Kit (rear only) H211a from CBC Automotive Products ($155) http://www.conbear.com/files/content.ph ... 2=bearings
Wishbone (lower) Front Bush............. # EP6250 bought from Pedders
BIG HORN
Wheel Bearing front,............repco and supercheap were charging 200 for a kit, (Thanks to KranKy for this info)
front wheel bearings for isuzu bighorn 92-98
Bearing wholesalers ltd
32008h $27.90
32009xh $29.78
60x75x8 metric oil seal $7.69
Auto Transmission filter kit,....Product number GFS456 from repco $90.99 and it took about 3L of transmission fluid
Fits the 1993 2 door imisher bighorn - Thank you to bighornoff road for this info.
Here are some Canadian Numbers for 4jg2:
Oil - Luberfiner LFP 5969
Fleetguard LF 3851
Fuel - FF 5160
FP 941F
