Hi all
just making a thread to post pics etc of doing my rebuild if anyone is interested.
no rings were broken every thing just worn out from 200k of bad oil changes before i owned it
so far i have engine out and all stripped down, hardest part was getting the liners out! ended up riggin up a sort of press with a old stand siting in the shed. just getting prices etc so hopefully have all parts end of january.
enjoy
ready to come out:
got the block all stripped down ready to take the liners out, then pressed them out with a manual hydralic ram
ground up a old flange to fit in and push the liners, worked well untill the last liner, so had to make another one out of 12mm x 40 flat bar, worked a treat
4jg2 engine rebuild
Re: 4jg2 engine rebuild
oops. haha
the liners
liner removed
oops. haha
the liners
liner removed
hey guys just sorting out what parts i need and was wondering do i need to get new head bolts? cheers
I used the old bolts on my 2.8. As long as there not pitted they should be fine
pig75 wrote:I used the old bolts on my 2.8. As long as there not pitted they should be fine
ok cheers, yea they look still like new
well i was cleaning up the block and fount this! in the cylinder wall not the liner it has coroded through were the coolant runs through one other cylinder has a pinhole.
any sugestions on what i could do?? or will the liner seal it again? never had water in the oil before and never used any water so it wasnt leaking previosly with the old liner in
Engine reconditioner should be able to weld that up good as new and check the other bores but it could cost as much as another engine. I wouldnt take the chance of it not leaking.
scruff123 wrote:pig75 wrote:I used the old bolts on my 2.8. As long as there not pitted they should be fine
DO NOT, DO NOT USE OLD BOLTS!, for the last month (or 3) my truck has been in getting some major work done. we reused the old bolts and had 2 snap puting the head on, and this was b4 we had reached full correct torque. Although it says you can reuse them they do stretch.
If you unsure of the engine before you owned it i suggest new. Headmaster in wellie can do a full set for about $150.
Demonic wrote:scruff123 wrote:pig75 wrote:I used the old bolts on my 2.8. As long as there not pitted they should be fine
cheers mate ill get new ones. good to be on the safe side
scruff123 wrote:well i was cleaning up the block and fount this! in the cylinder wall not the liner it has coroded through were the coolant runs through one other cylinder has a pinhole.
went and picked up my parts from isuzu parts specialists in auckland on saturday and had a good chat to the reconditioner, also found out when looking at the new liners that my old ones were cast iron so it has had a rebuild at some stage, that is why they were so hard to get out and also the reason for the hole in the coolant passage between bores, he said that with a little bit of corrosion and having to bore it out slightly to fit the cast liners results in very thin wall or a hole but because the cast liners are thicker and a press fit i dont need to worry. i am getting them to install the liners and machine the tops, hone them and remove/fit new camshaft bearings for $600, other parts i got were pistons, rings, all bearings, camshaft, gasket set, headbolt kit, engine mounts, cambelt, starter motor and full hose kit all for $1600, so that including machining and istallation of liners $2200 i thought was prity good.
will be gettin liners done in the next 2 weeks and then i can start putting everything together, will post pics etc of progress
