Well, I'm back after a short vacation. Ended up going out on a trip right before leaving, went out on a really good trail. Looking forward to going again. Also, since I'm back I finally changed my rear spring bushings and the shackle.
First, here's a few pics from the outing before the vacation:
Here's a hill top we took a break on, coming down I decided to take a different route... Here's the path I chose:
Just taking a break on the trail:
After getting back home, it was time to get the rear leaf spring bushings replaced with polyurethane ones. While doing that, I finally switched out the rear shackles. I'd already installed Calmini HD shackles a long time ago, but when I was in Japan I picked up these extended shackles from an MU in a junkyard (the Calmini one's on the right, the new one on the left):
As you can see it's a much longer shackle. Considering the Calmini one is already a little longer than stock. Here's the shackle installed, you can see just how much more lift it gave:
Here's a pic (granted a bad one) of the new stance. I also cranked the front torsion bars up a little bit more to equal it out:
