Hey does anyone know the diesel injector part number for a 1993 4JB1-T? I'm in the US and will likely have to order from ebay. The listings I find are for 4JB1 only, not the 4JB1-T, do the turbo models use different injectors? Rig is a Faster Rodeo 4x4 camper.
Thanks!
Waco.
OEM Zexel Bosch number for 1993 4JB!-T injectors
Re: OEM Zexel Bosch number for 1993 4JB!-T injectors
injector should work. You should also get by with 4jj1 injectors
Thanks man - A couple of pints on me when I drive over to NZ
paulthepilot5
geeves wrote:injector should work. You should also get by with 4jj1 injectors
JJ1 nozzles are not correct, they are designed for a vertical centrally mounted injector not slanted/offset type used in the JB1. This ends up with a very uneven spray pattern once in a JB1 bowl.
thanks for the clarification. Dont use 4jj1
Thanks for the clarification - Does anyone have a part number? The truck is a 1993 Isuzu Faster camper (JDM) VIN: TFS55 4jb1-T 2.8
I pulled my injectors - here's the number I found. Maybe it will help someone.
017 48-2090
017 48-2090
Roadrunner
