Help need injector pump 4jg2
Bighorn8865
Post by Bighorn8865 »
Hi all ive got a 95 bighorn im trying to get the injector pump out . I believe its not a mechanical pump as it has electrical plugs on the side and cant see a cable running to it. So far im up to the stage of locking the pulley in place and unbolting pump. How many mounting bolts are there and there are 4 im assuming steel fuel lines coming out from the back of the pump do i just disconnect them from the pump end unplug electrical plugs and other hoses and mounting bolts and lift pump out or will those fuel lines be in the way. Not much room in there . Any help i would really appreciate starting to panic as its already been off the road for 2 weeks. Cheers
