TFR9 Rodeo Suspension Lift
Flash
Post by Flash »
Does anyone know what the std measurement is from wheel hub center to wheel arch on a TFR9 Rodeo? I'm trying to determine if my vehicle has a suspension lift or not. At the moment my example measures 50cm from the wheel hub centre to the wheel arch... i personally think its at std suspension height (given that I parked next to what looked like a completely std Rodeo the other day and they were both the same roof height) at the moment and one garage thinks the same as me but another garage says its been lifted... hence my query
Re: TFR9 Rodeo Suspension Lift
from the manual
Flash
Post by Flash »
thanks for this...
so my vehicle has 31x1050x15 tyres which are best part of 2 inches bigger overall (so an inch in height) and my vehicle measures 825 to the center of the headlamp... am i right therefore in thinking that actually then, my suspension has sagged by the best part of an inch front and rear as it sits level?
measure your tyre before making that assumption. I measured a well known brand 32 inch tyre The result 31.1
