Turbocharger
Discuss all things related to 4x4
Jovito1158
Turbocharger
Post by Jovito1158 »
The turbocharger on my 4jg2 engine has broken twice, can please advice me of the possible cause?
jellis
Re: Turbocharger
Post by jellis »
blocked coolant or oil lines?
Jovito1158
Re: Turbocharger
thanks for the advice especially coming from you, Josh of the beautiful city of Sydney. I appreciate your taking a bit od your time to respond!
Btw,i lived in Marrickville from 1999-2001. I hope to go back to uor place for vacation in the near future.
Cheers,
Jovy
jellis
Re: Turbocharger
Post by jellis »
No worries Jovy, my girlfriend works in marrickville so i spend quite a bit of time around there.
now back to this turbo, is it a genuine replacement or a chinese copy turbo?
what failed on it?
Jovito1158
Re: Turbocharger
Well, the replacement was brandnew but lasted only fot about a month. The technical tell me what the cause why the turbine of the new turbo broke off from the spindle and fell into the exhaust causing clouds of white smoke.
Still,
Jovy
Re: Turbocharger
Most likely cause of that in manufacturing fault. If the turbine had a crack this could happen. If the bearing was loose it could as well.
Did it make any noise or vibration before failing?
Was it a genuine ihi turbo?
