Hello
What I can do to get more power and torque in lower rpm? What model of coils accel, msd I can use? I can use air filter from rodeo v6 3.2 1993? there are a good eletric fan?
thanks
Engine 2.6 more power
Re: Engine 2.6 more power
Extractors and larger exhaust always help. Different cam and injector chip might help but this can be expensive. If its good at high revs then a different air filter wont help much but you could try a k&N pod filter. Otherwise a bit of engineering could see an LS1 fitted
