Dmax warning tone
powerguy
Dmax warning tone
Post by powerguy »
Hi, does anyone know if there is a hack to disable the seatbelt warning tone in a 2015 Dmax? I live rurally and don't always want to put the belt on when doing multiple small trips around the block and the beeper doing its nut drives me crazy!
Re: Dmax warning tone
plug the seatbelt in before you get in the seat. Problem gone and mr plod will see a done up seatbelt on a casual glance so you shouldnt get done except at a checkpoint. Off course sitting on the buckle every day will remind you how the seatbelt should be worn for safety.
the real fix is to unplug the wire into the seat but they do check this at wof time and it may disable the airbag but since you are driving slowly around town you dont need safety features
Here I am telling you how to do it and not to do it at the same time. Even since I was a child I was in cars with seat belts and we had it drumed into us so much that I cant even jump into a car and drive across a car park without the belt on
best way is to buy a secondhand seatbelt out of a crashed d max and cut the buckle off the belt, then you can just plug it in when you want
powerguy
Post by powerguy »
Thanks for the replies. Geeves, my driving is around our block, not in town. Yes, unplugging wire could interfere with airbags and also trigger a fault warning, checked that option out already. Izuzurob's suggestion sounds best so far but will need 2 as it also triggers for the passenger! Just wish sometimes the manufacturer's would put a biit of thought into it as a workhorse requires different "features" to a Remuera Tractor!
Our company policy is all vehicles all times seat belt on. No Ifs buts or whatevers. Backing a car from one side of the car park to the other without putting the belt on is almost a sackable offence
powerguy
Post by powerguy »
Yes, different situation when you are employed or just shuttling around on your own place!
stardog
Post by stardog »
In my Toyotas to keep it from beeping I just buckle the belt up before I get in to drive it and it doesn't beep same thing on passenger seat if there is anything on it.
Works for me.
NPILE4JB1
Post by NPILE4JB1 »
I know this is an old thread but for anyone new who Google's this. There are 2 electrical plugs under the seat. Unplug the one going to the buckle on both seats.
For all the nae-sayers out there I always wear my belt when driving on the road but not when cruising around the farm in low range.
