Wanted 4jg2 Power steering oil pump
Only for Isuzu Vehicles and Parts in New Zealand
mrsuzu
Re: Wanted 4jg2 Power steering oil pump
Post by mrsuzu »
I mean the whole hose thing with connector ?
The part I showed is the part that the hose fitting bolts on to. You need the complete hose not the part I have.
If the isuzu is there but has no hose have a look round other cars to see if you can find one that fits. Try it on the wrecked isuzu before paying
mrsuzu
Post by mrsuzu »
geeves wrote:The part I showed is the part that the hose fitting bolts on to. You need the complete hose not the part I have.
Thank you. There is one isuzu on trademe http://www.trademe.co.nz/Browse/Listing ... 1034388070,
This got run bearings because of incorrect oil, its a 1997, please have a look and tell me how much is its real worth? Cheers
Why are you looking at complete cars?
On the face of it the price seems reasonable. The engine is the valuable bit. You would have one issue with a motor swap. The 97 will be electronic control. Options would be swap injector pumps or deal with a check engine light. Might be other wiring issues but not unsortable. Had it been auto could of been more issues.
Would of cost a lot of money to recon and then they ran the wrong oil? Even cheap petrol oil wouldnt of killed it that quick. Could be ok but treat with caution
mrsuzu
Post by mrsuzu »
geeves wrote:Why are you looking at complete cars?
Yup you got it, Wanted to swap the motor, But i will take your advice i will stay awy from it. cheers for that good suggestion, I've got that hose and wee connector cost me 60 bucks, is it an ok price? Damn i should have bought it beofre rather welding it...
mrsuzu
Post by mrsuzu »
I have got noise coming from dashboard specially when accelerating from lower gears, i assume something inside dashboard it touching with something, Is it easy to open the whole dashboards, Where do i start from?
