TF rodeo Torsion bar adjustment
magicdeo
Post by magicdeo »
It may be a silly question but how are the torsion bars on TF rodeos adjusted?
slightlydodgy
Re: TF rodeo Torsion bar adjustment
Post by slightlydodgy »
The adjusting bolts (27mm from memory) are on the chassis rails about in line with the front seats. Liberally apply crc or similar undo sway bar Adjust torsion bars to desired height -a jack under the chassis makes it easier Go for a little drive then check both sides are the same Reconnect sway bar then go and get a wheel alignment
magicdeo
Post by magicdeo »
Thanks for that. Do you just wind these bolts up that you're talking about?
slightlydodgy
Yup but they may be hard work -certainly not finger tight :D
turnturn
Post by turnturn »
Clockwise to raise vehicle
Anti-clockwise to lower vehicle
