dales isuzu mute 91
Show us your Rig!
Re: dales isuzu mute 91
yea im up with the rules work at a holden dealership, certing half in taupo then other half in hamilton as guy in taupo hasnt got quailications to cert everything im doing to it, lift rules have been around for a long time and has always been anything over factory is meant to be certed in the virm but who cares as long as its done propery
dalebroughton
Post by dalebroughton »
holy crap that sounds like a mission so am i going to need two certs due to body being modified and another for suspention?
dalebroughton
haven wrote:How come the custom tray doesn't fit mate? Oh is that how u did it? With a single cab rodeo? Are the interiors between the two identical? How about wiring? Got a coil sprung patrol that I'm putting under my mu but I'd like to go for a mini ute. Was thinking about cutting my shell into a space can sort of layout but a bit hesitant.. Big difference in room between the mu wagon and ute....
Keep me updated mate, will watch on keenly :) uea mate a huge difference with space thats why i am making storage into the tray etc and yea just the single cab as long as you get the matching models between the mu and rodeo the only difference is the back window and roofliner wiring,body and interior are all the same and the rodeo altho it comes with a bench seat has the mounts that fit the mu single seat rails
dalebroughton
isuzurob wrote:Thats annoying man cant just lift mounts on deck up or will it be to high?? no post yet sorry, yes same as yours, having trouble with cert regulations so sorting all of that before i start, i mite coil front and use a prado front diff, i already have a front and 2 rear hilux diffs with leaves and all steering linkages you need the parado high pinion diff to get the right drive shaft angles in the front but you just cut the mounts off and put leaf mounts on if you dont want the hassle of converting to coiul sprung how much have you looked into the sas conversion do you know roughly what you have to do i have got alot of awnsers over the last few weeks and would be happy to share if you need advice
I was going to just go leaf sprung as i have a complete front end but have found a prado complete front end now so will proberly use that along with all the hilux steering, have a hi pinion diff head, am getting a new transfer case flange made by family friend with hilux bolt pattern so i can use hilux front drive shaft for more angle as isuzu crosses are crap
dalebroughton
true thats not a silly idea either have you looked into what you are going to do with your gearbox crossmember to get it to clear?
The cross member will clear the drive shaft, everyone modifys the g-box cross member when they use leaves in the front as the rear hangers hit it on full flex
dalebroughton
ah another usefull peice of information cheers
I got lots of ideas but like i said wont do a write up until its fully built and tested to the limits in every way, so people have the correct information
dalebroughton
fairenough as you say wouldnt want others copying then finding it dosent work
