haven's MUTROL sas project
daisy
Re: haven's MUTROL sas project (early days)
Post by daisy »
haven wrote:You are sadly mistaken. I do not like patrols. The mu's driveline is lacking in the extreme sense hence the conversion and I like the idea of a unique looking vehicle. Driveline and a grill hardy make a vehicle. Why be a sheep all the time and drive something hundreds of others drive?
:oops: sorry if I offended you! I agree that the nissans running gear is one of the best and that the Mus looks cool!
Good luck lots of work ahead I'll be watching this build.
haven
Post by haven »
haha no harm done diasy, was not sure if your post was malicious orn ot, i suspected it just a misread impression on my behalf. hope to keep you entertained with the build :)
haven
Post by haven »
started rustkilling and removing as much as possible to prep the chassis:
haven
Post by haven »
primed and painted the chassis today :)
Captcol
Post by Captcol »
Looking good, nice work on the paint job
haven
Post by haven »
removed the original body mounts from the patrol chassis..
haven
Post by haven »
cleaned up shock mounts and painted coils get an idea of what my black and white scheme will look like..
muzila
Post by muzila »
Keep up the good work! I watching your progress to decide what path I will take with my rebuild.
haven
Post by haven »
put the springs, shocks and brake lines back on today. will repaint the brake lines and fuel lines once they are fitted..
realised today that the gq petrol fuel pump runs to the right of the vehicle so i removed the fuel hoses and will have to use the mu ones to trace down the left hand side ofthe chassis, better than having two stupidly long rubber fuel hoses crossing the motor to reach the injector pump and fuel filter..
still in the process of putting new seals in the sterring box. was trying to get the little oil seal that seals the steering column input shaft but seems i can only get a complete seal kit at 140$....
haven
Post by haven »
thanks for the comments guys.
muzilla, im looking forward to getting onto the engine too :) cant wait to get the rebuild kit and start stripping the motor down. that will probably become next priority oncei get the carport up and buil the a-frame to support the shell in the air..
