Wheel hub locknut socket
Posted: Fri Nov 18, 2022 9:06 am
by lukemclaughlin
I’m after a socket used to tension the wheel hub locknut for the front wheel bearings on a bighorn. It has 2 prongs that connect into the locknut. Any parts stores in Christchurch that sell this?
Re: Wheel hub locknut socket
Posted: Sun Nov 20, 2022 9:34 pm
by Chchbiggie
never seen one, i have always used a flat head screwdriver and hammer
Posted: Tue Nov 22, 2022 1:18 am
I use a nail punch and hammer
Posted: Fri Nov 25, 2022 3:31 am
by lukemclaughlin
Found this on Trademe, it’s on various other US and australian websites but shipping works to be more expensive so I went through Trademe. The diameter between the two pins is only slightly too small, less than 1mm. I sanded the inside edge of both pins with 80 grit and it fit the locknut perfectly. This now lets me torque the locknut to 30nm to seat the bearings and then helps set the required preload.
