Outer CV Joint replacement
Posted: Tue Nov 08, 2022 8:24 am
by lukemclaughlin
I have a 1996 Bighorn and am trying to replace the outer cv joint. I’ve tried hitting the joint off with a hammer but it doesn’t seem to budge. Is there a clip or something I’m missing or any other method to removing the joint?
Re: Outer CV Joint replacement
Posted: Tue Nov 08, 2022 6:54 pm
In theory there is a circlip inside the joint. The book says cut most of the way through the joint and crack the remainder with a cold chisel. It is possible to smash the joint off but it takes determination and a bad mood.
