Wanted Australian Tractor Spares or 4FC1 block for US Import
If you need something post it here and maybe someone can help you out
nchillbilly
Post by nchillbilly »
I an in NC in the United States. I have an Iseki TL4100 that has a 4FC1. The engine has a crack in the block.
The 4FC1 engine in it is the same as in Iseki and Komatsu and some other Japanese built equipment.
I know Holden used it, I know Hindustan used it. These wouldn't be the industrial version, but would be part for part swap.
I have several 4FB1's but they use timing belts, and that is not acceptable for an agricultural use engine. I am looking for a 4FC1 block so I swap over my parts in my 4FC1 engine into the correct block, no hanky panky.
If anyone would have a lead, I'd appreciate it.
-VM
